oh i see thnx seem like an easy mod plus better for engine..... thank you so do we get better mpg with this?
Theoretically yes - the blowby gasses essentailly decrease the effective octane of the fuel so if you have a lot of oil in the can, some increase in MPG should be expected... but maybe not large enough to notice, depending on how much blow-by your particular motor has.
Old thread but still relevant...
I've refurbished my oil catch system after it was damaged in an accident that totaled my FX. After buying my second FX, I've started swapping over all the aftermarket parts and the oil catch system got finished up this week. Here's a shot of the catch can setup before the wreck:
The aluminum plate was bent and dented in several places. Using a bench vise and some rags to protect the surface I roughed it back to flat. They I flipped it over and used a hammer to fine-tune. It's not perfect but I like knowing the history... it has character.
Setting the angle of the catch cans before mounting them
Cleaning, 1 coat primer, sanding, cleaning, 2nd coat primer, 24 hours dry time, 2 coats gloss enamel, 24 hours dry time, sanding with 1000, cleaning, 1 coat gloss enamel, 24 hours dry time, wetsanding with 3000 grit.
