Final kit dimensions were finished today. The ground points are not exactly as Gordon's kit. This FX kit has less redundancy and is not on display like some other kits. In fact, if you keep the engine cover on, you will only see a couple wires. This is a five wire kit.
1) There will be one wire coming from the battery and going to the passenger strut tower ground.
2) Then one wire from that strut tower point to the OEM ground you see in this below photo, a few inches below the grounding "octopus" on the side of the plenum. This OEM ground wire is tied both to the chassis and the front of the crank case.
3) Another wire from that same OEM grounding point will then connect to the driver side strut tower ground.
4) A wire will connect from the battery to the throttle body ground (on the TB, not the plenum)
5) And the final wire will connect from the throttle body to the transmission.
In this photo I have the battery to throttle body ground (#4) in place:
Kits will become available at the end of November. I am requesting all color options with some sample pictures so you guys can just make your choice. The color you see in the above photo is carbon. Since I started using carbon techflex on my hoses, I plan to make all the grounds black.
Shipped kit should be less than $100.
So far I think the people interested are:
1. Jumbo - black
2. Dopie - red
3. Bklynjohn718 - carbon
4. Stulax18 - color?
5.
If any of you guys have changed your mind about color or participation, just re-post the list with changes.
