I just installed the OEM sport pedal kit in my FX, Its not a difficult install but I thought I would put up some pictures for anyone else that might want to do this.
1. Before Picture
2. Pedal Kit
The part numbers need for this job include | 67840-CG010-Dead Pedal | 18016-AB010-Gas Pedal | 18014-AB000-Bushing | 18014-8H601-Clip | 46531-AB010-Break Pedal |
3. Remove stock dead pedal by turning the plastic screws 1/4 and pulling up, Replace old pedal with new, lock it in by turning the plactic screws back.
The Stainless Steel will need to be removed to get at the plastic screw underneath.
4. The break pedal is straight forward the original rubber needs to be removed and replaced by the sport one. Soaking the new pedal in hot water makes this so much easier.
5. Remove Stock gas pedal by undoing the clip at the back, once that is undone pull it forward and slide it off.
6. Install round bushing into sport pedal, slide on accelerator and clip back into place usin new clip.
7. Enjoy the look of your new OEM Sport Pedal Kit
I beleive I have seen the clutch pedal from a 350/G35 used on the E-break pedal I may try this, If it works out I will update
1. Before Picture
2. Pedal Kit
