alexd15680
- San Leandro
- 2006 fx35
Can you remove the clear coat if you are using detergent dishwashing soap?
yeah, i hear the zaino people use dawn before they zaino their cars, but eh, not for me. I'll just stick to the clay.
I have a handful of their products. Unfotunately, the store that sold them shut down, and I think I need a new clay bar.I dont use a dishwashing soap i use a product made by GRIOTS GARAGE its called paint prep it pulls off all the old wax without the chance of hurting the clear coat at all.
An abrasive is a material, often a mineral, that is used to shape or finish a workpiece through rubbing which leads to part of the workpiece being worn away. While finishing a material often means polishing it to gain a smooth, reflective surface it can also involve roughening as in satin, matte or beaded finishes.
Abrasives are extremely commonplace and are used very extensively in a wide variety of industrial, domestic, and technological applications. This gives rise to a large variation in the physical and chemical composition of abrasives as well as the shape of the abrasive. Common uses for abrasives include grinding, polishing, buffing, honing, cutting, drilling, sharpening and sanding.
Abrasives give rise to a form of wound called an abrasion or even an excoriation. Abrasions may arise following strong contract with surfaces made with things such as concrete, stone, wood, carpet and roads, though these surfaces are not intended for use as abrasives.
Surfectants and solvents are classified as ''Chemical Cleaners'' (Not Mechanical)
Did you come on here just to be a dick? First you are accusing people of trying to push certain products, which no one in here is doing. And now are saying we are all stupid?Thank you.
Finally intelligent life.
I agree with you 100%
The phrase "finally intelligent life" suggests that up until then, there was none. Now if something is not intelligent, then it is unintelligent. Therefore, you were indirectly calling everyone else unintelligent. Am I right?Look, no one was directing a comment at you, If you think you're stupid that's your opinion. No one is going to argue with you.
I was unaware that it would cause anyone distress by complimenting another person's intelligence.
Intelligent people don't stoop to name calling.
They know that profanity is the effort of a feeble mind trying desperately to express itself".
