Great find, Ckai! John Bolter is no longer at South Bay Infiniti so it looks like cerritos for service!
Yeah, he ended up going to South Bay NISSAN.......f'ing assholes there, no joke......
Anyway, I just performed this service myself on Friday and this took exactly 30 minutes. I did this with 67K miles on my car and the old fluid smelled BAD and looked very dirty, looked like it was mixed with a lot of metal shavings since the bottom magnetic drain bolt was COVERED with metal shavings.
This video is SPOT ON with the directions.
(No need to lift car up, just crawl under, still plenty of space!)
Materials:
10mm hex nut $2.49
breaker bar
pan to collect fluid (Smells BAD)
75W90 Full Synthetic Gear Oil ($7.99 a quart) manual says 80W90 but 75W90 should be fine
Pennzoil fluid pump $6.99 (made for quart size bottles)
use the 10mm hex nut to open up the 2 bolts, one on the top right side and one on the bottom facing out towards the muffler, very easy to get to (make sure you use a decent long breaker bar, I used a short one and ended up smashing my finger because the bolt cracks open right away and my hand flew up against the suspension bar, all black under my nail now)
The bottom bolt is the drain bolt so place the pan directly under. Let it drain completely until it stops dripping, hand tighten this bottom bolt.
Start pumping the gear oil into the top right side. pump 1.4 liters ~ (1.3 quarts) into the gearbox or until it starts dripping.
I pumped ~ 1.2 quarts because it started dripping alot and couldn't pump much more into there, so it's probably mixed with .1 quarts of old fluid.
Tighten both bolts tightly! That's it!
---------- Post added at 10:58 AM ---------- Previous post was at 10:57 AM ----------
In other words, just follow the video exactly step by step.
---------- Post added at 10:59 AM ---------- Previous post was at 10:58 AM ----------
Total price in parts was $29.xx which includes the 10mm hex nut at $2.49.
Save yourself the money and do it yourself! This is just as easy as doing an oil change, the only hard part was pumping the oil into the gearbox. It took a lot of pumps but it's a good workout with that wrist action.
---------- Post added at 11:02 AM ---------- Previous post was at 10:59 AM ----------
Who at cerritos did you talk to to get these prices? Can you hook us socal guys up?
PM me for his contact info.
