Knocking - Low RPM Knock
update: they took off all the belts and said the noise is gone, so hopefully it is just something simple.
what did you tell them to look for? My dealer seems to think its normal, but I think I want a second opinion... Very curious to hear what your dealer finds out.
They had their head mechanic jump in the car and I took him for a slow drive around the parking lot, driving very slowly around 1000-1500 rpm's we could hear the knocking.. He didn't really tell me much, but he told the service guy to set me up for a full diagnostic check. Driving a loaner HR G35 now...:eek: (They can keep my fx..hehe)
I will update when I find out more.
Also did you try another dealer? Try searching g35driver for mod friendly dealers in your area.
Thats my plan when I bring it in next time, to have a tech go on a drive with me. Hopefully he hears it because I hear it every day going up the building garage and driving into my house garage.
If my dealer still says its normal, I'll bring the FX in to West Houston Infiniti for a 2nd opinion, as they are the next dealer in line with the least amount of complaints. My buddy is on Driver, and he drives across town to go to the same dealer as me...
They called me today and said they checked all the accessories and the noise is still happening, next they are going to drop the oil pan. My FX will probably be at the dealer for another week.
i'm starting to hear the exact same noise from mine as well, i checked my muffler bearings and they where fine :tongue:
seriously though i wonder what it is
Finally received my car back, here is the invoice... ( I had to type all this, so there might be some errors)
#2 MAIN CRANK BEARING CLEARANCE OUT OF SPECS.
REPLACED SHORT BLOCK ASSY .RECONED HEADS
BELT FAN 11720 4P10A
ENGINE ASSY SHORT 10103 CD0M0
GASKET ROCKER COVER 13270 8J102
GASKET ROCKER COVER 13270 8J112
GASKET CYLINDER HEAD 11044 EA200
GASKET CYLINDER HEAD 110044 EA205
GASKET OIL 11121 31U00
GASKET OIL 11121 31U10
THREEBOND 1217H GASK 999MP 1217HP
SEAL O RING 22131 4M505
SEAL O RING 21049 31U04
SEAL O RING 21049 31U03
GASKET WATER INLET 13050 31U00
GASKET WATER INLET 13050 31U05
WASHER OUTLET 11062 AL501
PILOT CONVERTER 12330 14L00
SEAL O RING 15066 5E510
SEAL OIL CRANKSHAFT 13510 31U10
SEAL O RING 15066 2Y510
SEAL O RING 15066 31U02
SEAL O RING 15066 31U03
GASKET SOLENOID 23797 2Y508
SEAL O RING 15066 ED010
TENSIONER CHAIN 13070 8J12C
TENSIONER CHAIN 13070 8J12D
CHAIN TIMING CAMSHAFT 13028 JK20B
CHAIN CAMSHAFT 13028 JK00A
TENSIONER ASSY CHAIN 13070 EY00A
SEAL OIL, VLV 13207 84A00
GASKET OIL FILTER TO 15239 AL800
GASKET ADAPTER 14032 AM600
GASKET MANIFOLD 14035 8J101
OIL FILTER 15208 65F0C
WASHER DRAIN 11026 01M02
LONG LIFE ANTIFREEZE 999MP AF00P10
POWER STEERING FLUID 999MP AG000P
PLUG SPARK 22401 5M015
PUMP ASSY OIL 15010 8J10A
LIFTER VALVE 13231 2Y910
GASKET CATALYST 20692 65J00
BOLT 54550 CG100
GASKET WATER OUTLET 11062 4P100
PER LINE #1 MACHINE CYC. HEADS REPLACE VALVE GUIDES
FOUND # MAIN BEARING DISCOLORED AND BEARING CLEARANCE OUT OF LIMIT SPEC. >0.0026 IN #2@ 0.0040 CALLED TECH LIN WAS TOLD CHECK CAMS=OK REC SHORT BLOCK ASSY . PERFORMED CYLINDER BALANCE TEST – RESULTS INCONCLUSIVE. PERORMED OIL PAN TEAR DOWN. PLASTI GAUGED MAIN BEARINGS, FOUND #2 DISCOLORD-UNEVEN WEAR & OUT OF BEARING CLEARANCE LIMIT (SPECS NO GREATER 0.0026” ,@0.0040”#2) CALLED TECK LINE, ADVISED TO CHECK CAMS FOR SCORIN- FOUND NO SCORING. TECHLINE RECOMMENDS REPLACING SHORTBLOCK.
DISASEMMBALED ENG.BLOCK, PSI TESTED, REPLACED VALVE OIL SEALS. AND SURFACED CYL. HEADS, REASEMBALED ENG. ASSY. AND ADJUSTED VALVE LASH, REINSTALLED ENG. ASSY. RESET IDLE RELEARN, TEST DROVE CAR OK AT THIS TIME.
wow, they itemized everything didnt they? Glad you got your FX back! Seems like they had it for quite a while.
Short block replaced and reconditioned heads, all under warranty. Exhaust rattles a bit now....but I am not complaining, I will fix it after I am done with my move.
