JJFX
- Green Bay WI
My Fx has 47000 with warranty up to 2010- My seat squeaks/creaks every bump- I tried greasing etc~
my seat has started becoming very noisey. what sucks is I had a spare perfect seat frame but gave it to someone else local that needed it because mine was fine then
fx seats are so heavy too. need another solution here, I wouldn't mind even manual tracks if it saved almost 100lb's between the 2 fronts & eliminated the sqeaky crap too, hmmm, I've been thinking about this but only solution I can come up with is a custom seat frame to be able to keep the same upholstery & seat shape, not too easy to do & still maintain some adjustability...
My driver's seat squeaks when going around turns. It's not the bolts at the bottom that are squeaking, it is the side of the seat (the leather) rubbing up against the side of the car. It is really annoying. The seat is extremely close to the side of the car.
There's also this DIY that could possibly fix this.
http://g35driver.com/forums/body-interior-exterior-lighting-diy/147489-diy-possible-creaking-seat-fix.html
I want to try this but how do we remove our driver's seat lower plastic trim pieces? Is it necessary to remove the trim pieces to get to these bolts?
