with cars? maybe theres not too much I can't do if I really wanted to do it I guess, everything else I probably suck at though
there is no easy solution to the creaking seat...
I'm seriously considering setting the seat in place, removing it & welding it up, then cut all the motorization & track work out, make the seat solid & light in just one position. only easy solution, probably remove ~40lbs per seat I think, they are extremely heavy, but would probably bug me too that there not adjustable, that's where it'd get a little complicated, cause then the weight starts to go back up again as adjustably is added back in, is all the crazy work to build custom manual adjustable seat tracks worth it to only save I'm guessing 20-24lbs per seat? maybe?...
a complete seat swap is the next logical alternative & probably the real best solution, but then your talking maybe a complete custom interior to get it to tie in right depending on what you choose as a seat. would be awesome to be able to match the upholstery though & just have to reupholster the 2 front seats to match the rest of the interior., I've found close but not a perfect match to the brick leather... gotta still match the rear seat too... that's probably the ultimate solution though, new lighter buckets, but to do it right would be quite a few $,$$$'s, maybe something to add to the wish list for next winter
see some guys think shoot a little wd40 in there or just live with it or??? but these are the things I think of, sorry man, can't help it
but yeah, if your under warentee then bring it to infiniti
