- Southern California
very nice welds!
looks clean now ... NICE
Got some questions for you guys.
I am thinking of getting the rear lateral bracing, rear lower tie and front ladder bracing. I already have the NGR STB.
Will these make the car too stiff? Is it better to have both the front and rear similar stiffness for handling?
Will my setup cause unbalanced struct stiffness between front and rear or should be fine?
Any input is welcome.
Thanks,
Thanks Psiclne.
For the front, will the front lower engine tie be more ideal or the front ladder? Should I be doing the installation before or after the wheel alignment?
If you get one, get the front lower engine tie.
I would do wheel alignment after install. For rears, I marked the bolts so didn't do an alignment.
At nissan they charge $100 for an alignment, I overdo it but get it done yearly. Specs are typically within range, just fine tuned. Worth any potential bad wear on tires for me.
Any particular reason for going for the engine tie instead of the front ladder?
Final brace - ladder brace - was installed today at the dealership. Pictures to follow.
So is that like extra labor when you do oil change from now on? Looks like it's in the way of the plastic cover thingy.
They charged me for two hours of labor at the stealership. Which made me feel good and bad, in a way. Good because I tried for three hours to get this thing on and failed even after going to a shop with a lift and an impact wrench. They couldn't break the nuts either. Bad because that translated to about $220. I believe that job shouldn't take more than 30 minutes if you have the proper tools.
Before going to the dealer, I had installed three of the four shoulder bolts and couldn't get the fourth one in because the existing stock brace had moved a little and obstructed the last hole. So the dealer had to break the nuts that I couldn't, then move the stock brace, tighten it down and then install the GT Spec brace.
I did NOT get an alignment because I planned to get the Eibach Springs installed the next day, so that cost wasn't part of installation - and it should be included if you do the full set of bracing, in my opinion.
Don't Mess with Yohan!
---------- Post added at 09:18 PM ---------- Previous post was at 09:11 PM ----------
+1...
Get Stillen
or
Get GT-Spec
or
Get Strong (but fckin unnecessarily expensive, up yo a$$) Strut
or
Get GT-Spec, carbon wrap it
or
Get UTR dry carbon (some guy was selling at the .org)
or
A strut is a strut. There won't be any significant difference whether you load it or wrap it or it has pivot ends or it's made of alien metals or anything unless you're going with a 4 point strut (which won't fit FX) like the one in 370Z:
Get an affordable or good looking (or both = GTSpec) Strut brace and combine it with other braces.. THAT will give you the difference.. Not the two-point strut itself..
