muchilus
- Dominican Republic
guys, i have reemplace the oxygen sensor twice, trying to above the problem of the DTC check engine light. the p1283 correspond to the bench 2 sensor 1, and the p1273 to the same sensor 1 bench1.
i have inspect with scanner, the fast fuel strims of the bench 2 is always working at +25% (indicate too lean), when you check the bench 1 at the same time, and is working properly, -1.5% - +0.7%.
-i checked the properly measure of ground and voltage of the harness
-i'm inspect any leak on the PCV, OR COLD INTAKE system to the throthle body.
-the only possible chance is to check the header exhaust to see if there's any leak.
any suggestion guys?
