- 2017 QX70S
- Name
- Andy
Here is the Autozone part that I use, http://www.autozone.com/autozone/pa...ing=search&itemIdentifier=245770_517010_5972_
It when up $10? Wow. Since the access port on the Spectre intake tube is smaller then the tube that goes to the valve cover, I cut about 1" of the tubing that comes with the kit and use it as a spacer so that the oem tubing can fit snugly on there. You will need to buy two hump coupling like this for ease with bending. http://www.ebay.com/itm/3-PLY-UNIVE...es&vxp=mtr&hash=item23186f5cc4#ht_2927wt_1237
Here are two pics for your reference.
