- Boston, MA
Now I know it was stated that I would need at least 20mm spacers to pass the calipers...correct?
Over stock 06 calipers, you'd need 15mm min to clear the stock wheels. Can't say exactly how much you'll need for your wheels..
Justin quoted me $850 for the front brake kit, and about the same or lower for the rears. He could not give me an exact price for the rears because he is waiting for the machined part that Turbo talked about in his writeup, but definitely lower than $2K out the door. He is going to call me in the morning with the measurement and a pdf so I can see what or how far its going to stick out on my wheels. Also on another positive note these will be ready to bolt on at any shop, no mods needed for the bolts.
1) The rears WON'T be plug and play. Justin needs to talk to Joe to get a slap on the wrist. You'll at least need Turbo's ball joint adapters and you'll probably need some other bolts.. Read up on Turbo's post.. And talk to Joe, not Justin.. It looks like Justin doesn't know shit.
2) So far what Turbo said and Joe agreed was that rears would be more expensive than fronts. $830 is what I paid for the fronts and they were mostly plug and play if you don't count in the cut bolts.
3) I might be a little drunk but did I say that it looks like Justin doesn't know shit?
