Part # B-DNCI-333S
A bar for Infiniti FX35/45 '03-07
I bought this off ebay. I don't think this is the exact same as the Romik:
http://www.burtmanindustries.com/zoomprod.php?id=fx_rom_bull_03_up
It is stainless steel, and I put it on the scale: 20 lbs. It doesn't block the Laser for the brake/cruise feature. Installation would have been easier if it wasn't so cold.
Not 100% sure how I feel about this, but I put it on to prevent any more dings to the front of my car (parallel parkers). One person just backed up into my car and cracked my license plate holder, but that was it. There are 4 mounting brackets, I only used two bottom. The top two bolt onto the frame where the radiator is. If that get broken, that's big $$ to fix. It's sturdy enough with the bottom two main brackets and I did a test drive and it's on there good.
It's a tight fit with the plastic undercover. You have to remove it and bolt the brackets on. I did a little plastic trimming on the edges of the cover to make it easier to put on/off.
