:dito:
Shell and BP may the worst of the fuell from the shell stationsays it does not mean V with the fuel is good ,a good advert to it May.Hess is good.The station and the station is not egual to,each hass diffrent fuells and with 93 writes that does not mean with so much gone .BP donuts and coffe is good and looks nice this station .
The manual says use at least premium gas (91, 93 depending on what station/state). If you're using less than that you're hurting your vehicle. The compression on the engine requires the higher octane gas to run at full potential. You may be save a bit at the gas station, but you're hurting your engine in the long run and probably getting worse gas mileage, and therefore filling up more.
I didn't understand a word. ?
Pretty sure all gas is basically the same. It's not like some gas stations get their oil from somewhere other than under the ground. Hell, some stations may even get it from the same processing station. The only difference is the additives. That Techron and V-power stuff, if that's even anything. I used to get my gas from Tom Thumb (Safeway/local grocer), and they said it was on par with Exxon's gas. Usually at school I just get Shell because it's closest. One thing that sucks is the winter blend some stations use. I made 7-10 less HP compared to last summer, and nothing was different. The tuner said the dyno compensates for temp also, so that's one reason it didn't go up.
