Taking off front grill?
robb<35>
maple, ont
Does anyone have a diy to take off the front grill? I'm having mine painted tommorow but it would be much easier if someone showed me how to take it off, thanks :top:
Humberto or Deecarp might chime in as they have done it - also Turbocad.
The way I do it is take off the top plastic pop rivets and yank the grille off towards you.
or if you want to do it the proper way - remove the rivets on top and if you look at the corners of the face of the grill you will see 4 square plastic things with a flat head slot on them..rotate these and the grille should slide off.
def take the emblem off, most times just lift it off with a screwdriver but gotta be carefull not to make marks where visable on the emblem. don't even bother if your just going to paint around it, it'll look like ass & start peeling there too
removing the grille is very easy, top clips: pop the centers up a bit then the whole clip comes out, in the grille got those 4 1/4 turn flat head's or you can just pull them out too like jeff said, at the bottom of the 06 up grilles there are 2 more locking tabs that you can just reach in from the top & slide foward... it's easy once you get the top clips out you'll figure it out
Nope, when you remove the emblem there will be a backing shaped like the emblem.
Hm, wonder how that looks, do peole normally do this and leave it be?
Doesn't look good, it will look like somebody stole your emblem. Most people leave the emblem on and paint the whole grille black or all black with a chrome emblem.
Here are some examples
Black w/chrome emblem
all black
