Hopefully by then Z1 can get their hands on the Rear braces as well. I missed out on them the last time.
There's nothing official yet, Keemo. This was started as a interested list. Once Z1 actually gets these produced and in inventory, then we'll have an idea on price, quantity, etc.
gtspec pricing for the front brace($259) and 4 point brace($249).:neutral:
http://www.gtspec.com/index.php?nav=products_category&pid=291&cat=153
1. jc'sfx - 4 Point Brace
2. Dr.2K - Front Lower Tie Brace & 4 Point Brace
3. gto-dave - Front Lower Tie Brace & 4 Point Brace
4. fxlr8 - Front Lower Tie Brace & 4 Point Brace
5. Cube - 4 Point Brace & Rear Lateral (if available)
6. Psiclne - Front Lower Tie Brace & 4 Point Brace
7. Mongolian - Front Lower Tie Brace & 4 Point Brace
8. Fothion - Front Lower Tie Brace & 4 Point Brace + (2 rear braces) Still In.:top:
9. Humbertocali - Front Lower Tie Brace & 4 Point Brace
10.BaBaLuwee - Front Lower Tie Brace & 4 Point Brace
11. trainerKEN - Front Lower Tie Brace & 4 Point Brace
12. themercant Front Lower Tie Brace & 4 Point Brace + (2 rear braces)
13. turbocad6 - Front Lower Tie Brace & 4 Point Brace
14. gchristopher9 - front lower tie & 4 point brace
15. LAXMAN - 4 point brace
16. EgeFX - Front Lower Tie Brace & 4 Point Brace
17. DatMan - Front Lower Tie Brace & 4 Point Brace + (2 rear braces)
18. Asherchy - Front Lower Tie Brace & 4 Point Brace
19. aiya - Front Lower Tie Brace & 4 Point Brace
20. soonster - Front Lower Tie Brace & 4 Point Brace
21. Keemo - Front Lower Tie Brace & 4 Point Brace
22. Krayzie - Front Lower Tie Brace & 4 Point Brace
23. Airvtec - 4 point Brace
hey guys:
Just want to say thank you to all the member here that support our products. Got to thank JC for being patient with us during the test fit.
Yes, the brace is a bit pricy compare to the rear tie brace, but there are more hardwares involved for both of the braces.
The front tie brace required a subframe rivet set which make it possible to mount the bracket into the chassis. In addition, the mounting brackets are CNC cut to precise position for most accurate fitment.
The mid 4 point brace required custom bolts and studs to replace the stock bolts. The reason for the special bolts is because the mounting point are hidden within the OEM chassis braces. In order to securely mount our brace into the mounting point, we have to custom a studs/bolts solution to fill in the gap between the mounting point and our brace.
We should have pictures of the harwares posted shortly. If you guys have any questions, don't hesitate to send us a PM or call us at 631-586-3500. Thanks again for all the support !![]()
Mark.
