hey guys:
Just want to say thank you to all the member here that support our products. Got to thank JC for being patient with us during the test fit.
Yes, the brace is a bit pricy compare to the rear tie brace, but there are more hardwares involved for both of the braces.
The front tie brace required a subframe rivet set which make it possible to mount the bracket into the chassis. In addition, the mounting brackets are CNC cut to precise position for most accurate fitment.
The mid 4 point brace required custom bolts and studs to replace the stock bolts. The reason for the special bolts is because the mounting point are hidden within the OEM chassis braces. In order to securely mount our brace into the mounting point, we have to custom a studs/bolts solution to fill in the gap between the mounting point and our brace.
We should have pictures of the harwares posted shortly. If you guys have any questions, don't hesitate to send us a PM or call us at 631-586-3500. Thanks again for all the support !
Mark.
