Vibration after getting new wheels
I am noticing some vibration and play in my steering at high speeds since I got new wheels and tires. Tires are slightly wider than OE size (see signature). Could this be a balancing issue or front end alignment issue?
Thanks
Did you use hubcentric rings? If so check air pressure and have them rebalance them.
1 more thing to add is , your EXE rims, did they come in 5x114 or did you get them redrilled?
nevermind, I looked it up and 22" don't come in 5x114 (except for 626fx:top:)
Thanks Merchant! I see you got your answer on 5X114. It has been a couple weeks and I really noticed it this past weekend in a long trip to Knoxville, TN.
Thanks TrainerKen! I had the tire pressure checked as well and there were no issues. You think a realignment is needed because I went with a wider tire????
glad to hear you got it solved. Exe is Axis Wheels right? If so all Axis wheels are hubcentric and not lug centric (that's what the rep told me anyways).
