ROI there seems very low. $6K for mid 14s, barely a second off the stock time?
I don't think stock 35's are in the 15's
keep in mind that in order to do high 12's will take a lot more than just a jwtt, the motor itself is a limiting factor. the stock engine is good to around 400hp or so, to see the kind of #'s that rookie see's will def need a built motor to be able to really take advantage of that tt setup, forget 8K, your looking over 20k to see hp #'s over 500. a jwtt on a stock block will be detuned to keep it from popping. a stock motored fx with a jwtt might be a high 13 second car, still very respectable...
Is one option known to be far more reliable than the other?
oh yeah and the reason it's 8K for me is because the proginal deal he gave me was a used TT with 1000 miles on it plus BBK....usually would be around 12K....forgot to mention that.
question is... how are you going to use that power and how often are you going to use it?
I have had my stillen for over 2 years without one issue, noise is the only. I actually took the stillen once out because I thought what's the point of having this when I only really used it once back in 1996 at a drag strip in socal..... After feeling the stock power again I put it back on, this time stage 4. Since putting it back on I haven't done anything that needed stage 4, track events...nada.
I think the only justification in going all out and spending gobs of money is if you plan on tracking the car....or entering in events where you can somehow earn your $$ back or at least awards. Just doing it for being the quickest on the streets is for teenagers with a death wish..(I was there once and almost died in my CRX:frown: at 19, while my wife was pregnant)
My wrx wagon has enough power for me when I need it and handles better for the power it produces..
If I could do it all over again I would of just got an FX50s hehe... all the above is my opinion only.
amen, how much is enough? my only goal was to make it as quick or quicker than a 45, just to have some balls. is it ever "fast enough"? no such thing, but, like said above, how much do you really want or need? I did consider going all out & making a real beast out of it, but then reality check set in, I want a daily driver, back & forth to work, home depot whatever, to spend 25K or better just so I can then have enough power to start breaking the rest of the drivetrain? been there done that, it was & can still be much fun, but again, what is it that you really want?
personaly, with restraint, I wouldn't dismiss the jwtt as less reliable to be honest, yeah, there are more potential problem areas, but not to the point of being unreliable if installed well.
also, since were on the subject, before thinking about the stillen sc, you really HAVE to hear one, in person, to make sure you can live with what it sounds like.... it is very very loud to say the least, the jwtt is probably worth the extra $$$ just for what it sounds like over the stillen![]()
so yeah i did the appropriate math....
if i get all those extras....this is the approx. total
________________________________________________________
JWT TT + BBK + install= --------------------------- |$8,000.00
-PWR Radiator-----------PWR5646 Infiniti G35 ------ |$629.00
-Camp2 monitoring system--------48001-AK001 CAMP2 -|$535.00
44999-AK011 Temp. Sensor and Harness Set -------- -|$61.97
44999-AK021 boost Pressure Sensor and Harness Set-- |$133.97
-Innovative Wideband------------------------------- |$199.00
Total:approx |$9558.94
but it may just bump up to $10K with the extra install time.......
and yeah what you guys are talking about ^^^^
I'm actually planning on going to the track and stuff once it's all said and done, so it's not like its just to have the meanest fx on the streets. But then again.....a TT FX is pretty Ballin' just to say you have it haha. But yeah i know I'm a teen, and i know i want to go fast, but i control myself when it's necessary. I may even represent VinnyTen at local shows so we'll see what happens..........................
again, if anyone has any ideas let me know
