How do you clean under your hood?
I use the 'engine spray' selection at the coin wash, then rinse with low pressure cold water, then wipe every thing down as best I can at home.
Just make sure to cover up the intake. I usually use a platic bag, or stuff some microfibre cloths in there.
I use a toothbrush and simple green, just spray it down after. I don't cover anything at all but do try to avoid spraying directly on the air filter.
I follow these general steps especially the part about never detailing a hot engine.
0. never detail a hot engine. you could crack your block.
1. cover intakes and electrical.
2. degrease.
3. brushes to remove the deeper seated stuff.
4. rinse off.
5. high temp sealant/wax on the metal.
6. rub on a vinyl/rubber sealant.
Here's a fuller explanation:
http://autogeek.net/engine-guide.html
I use soapy water in a spray bottle and spray it onto one of those blue automotive paper towels and wipe everything by hand. I then polish up the plenum and intake :4tongue:
I had my car detailed by somebody who does it in his spare time, and I cringed when he soaked the whole thing in degreaser and then sprayed Armor-all everywhere.
I also cringed when he used an orbital to apply wax. Needless to say I've done everything myself since then :err:
I guess I've been doing it wrong.:embarrassed: It's just easy and it works..
i use simple green to get all the dirt off then i dry it and spry this product called CD2 (engine detailer) i let it set for 20min then turn car on for another 20 min. engine bay comes out mint!
