I cant answer the offset question -
But the Tires will be ok - when I got my 20X10 I used my stock RSA tires on them for a couple months.
Ege, is this going to be your daily driven wheel/tire combo? If so, because you are an AWD I would stick as close to the overall oem wheel/tire diameter and height. From my experience with my nismo track wheels I have had the AWD light come on a few times then disappear when the engine was restarted. But I do not know for what reason and nothing happened. I only have my track wheels on a few days at a time and the most was for about 2 weeks.
I personally would not go with different offset wheels on a AWD FX. Just wanted to give you a heads up since i see that you have an AWD.
They'll be summer tires & wheels. I already have oem 20s on oem size tires for winter. I used OZ Canyons 20x9.5 on 275/45/20s summer and winter without problems but I was not lowered. The wheels I'm planning to get come only on 20x8.5 or 20x10 sizes and I personally wouldn't want the bulge with 8.5 width. That's the reason for the questions.. I think if 9.5 didn't have any issues on AWD & slippage 10 shouldn't have as well.. I'm just worried on the rub..
Doc, are you using different width track wheels? Maybe I should go with 20x10 or 20x8.5 all around...
You shouldnt have rubbing with the 275/45/20.
My rims are 20X10 and i have 285/50/20 on them with no rubbing.
Im lowered on Eibachs.
My track wheel specs are:
Front: 19x8.5 +25 285/45-19 - Yoks Advan ST tires
Rear: 19x9.5 +30 295/45-19 - Yoks Advan ST tires
Ege, I would stick to the same size width wheels all around for an AWD FX. Your OZ canyons were 9.5 all around right? If so I wouldn't expect any problems with that setup. Its just looks that the different width wheels seems to trigger something in the AWD system in prolonged driving.
I didn't notice any problems with the nismo's in normal driving or even when I drove it pretty hard in an autocross event. But just to be safe i would still stick with same widths for my daily driving purposes.
The light never came on from a stop and start or even at the drag strip with even harder starting launches. Anyways, its just a issue to think about. I don't think there is any real need for concern but just something that I experienced. Good luck with your setup.
Will, what offset you're running? The wheels I'm looking at is at 42 offset & 20x10.. That's about 27 mm less inner clearance.. Wonder if that'll be a problem.. It's a lipless wheel though so there might be some more clearance on the caliper side..
I cant remember to be honest - I'll take a look see tomorrow to see what the lil tag on the back of the rim says. Bert, Doc & Dave were there at the LAX meet the night I got them put on - do you guys remember? Oh Rookie was there too -
