H&R springs
I would see how it looks without the spacers first. You're running a conservative offset, but that can be offset with an oversize tire if you want to go that route. You're running more aggressive than me, & I'm cool with what I've got. I got the bulge though, so it's an illusion on the offset, & makes it look more aggressive. Spacers on the whole suck, & I would steer away from them.
I'm thinking, get the right offset or nothing
I think it was more luck than anything that you got the results that you did with your wheels dave.
Carlos just get what makes you happy...
If you want it dunked then get the Eibach's
If you want a softer and a bit lovwer ride than stock get H&R
case closed.
case closed.
Thanks once again. I think my offset is good. I'll try to take some better pics and post them. Also need to take pics of the intake. Most likely will do it on Saturday when my FX is all cleaned up. She is all messy right now. Damn storm watch. hahahaha
Luck is good, but I've also been looking for wheels for quite some time, so let that be the result of the avid shopper :biggrin:. And I'm not denying that I would like to be pushed out 10mm more than I already am. Carlos is inquiring, so I think opinions are what he's looking for. He doesnt know what will make him happy, so I think this exploration is good. Re. offsets, me & you are running ET35, while I believe his is lower. Yours looks tucked, & mine not nearly as much. Tire bulge has alot to do with the look.
Ok, so I'm going to go get my H&R's during lunch. Going to meet the guy at 12:30 by my work. This way I don't have to drive all the way to La Habra. Think I'm getting a good deal for $245 and delivered.
What do you guys think?
fair deal, though I still think you should try drive both
cool, glad I got a good deal. Other sites were selling for over $300.00. Would have been cool to drive both, but I want a softer ride. Once I install the springs, is it a lot of work to install the rear sway bar?
Sounds like a good deal.
yeah, thought so also. I'll probably end up getting them installed on Tuesday after my trip to AZ. I'm taking that day off also just to relax. Then back to work on Wed.
Do any of you know of a good place near the SGV where I can take it to get an allignment? A lot of shops don't do 22's.
Ok, just picked them up. Checked and got the right part number.
Now can't wait to get them installed.
Here ya go Dave
lol Will. Your too funny.
Will, do you know of a good place where I can go get an allignment in our area?
You can try LMS in Monrovia......
http://www.luxurymotorworks.com/
Not sure if they can do 22's though......call them up and see.
I also saw a place that was highly recommended on the G35 forums - lemme see if I can find it for you
Here it is -
Alignment plug for a good shop - G35Driver
http://www.templecityautorepair.com/
Startbutton99 said:
55 bucks!
They will align your car front and back. And put everything back to spec. as close as possible even if you dont have any supporting mods for camber and toe, etc.
They take really good care of your car.
Pro- THey will get her done right, and take watever measures to do it right.
con- It may take over 30 minutes. Esp if you dont have the right mods with your lowered suspension. e.g. A toe bolt can only go so far if its not aftermarket. Camber kits and the like.
I vouch for these guys quality of work!!!
talk to john or henry. Henry will most likely work on your alignment.
They also have Good prices for tires. Just ask for a quote, it will def. impress you!
