Okay:
$187.50 labor
$44.80 for 4 Spacer - headlining - 73982-4l700
$.64 for 1 Spacer - headlining - 73982-9e000
All this trying to fix a squeaking noise from the front console and dash. I searched both the org and scene and found that it could be the following (at least suggested):
1) Windshield moving against insulation because it cracked during the cold (the cold part makes sense as it only started when it was winter)
2) Vents in front (closest to windshield - the defroster ones) are cheap plastic and they rub and make a squeaking sound.
Either way, the dealership could not fix it. They said only other attempt is $375 to remove and replace the dash board.
Any thoughts? Should I take it in for the $375? Cut my losses while I can? I would greatly appreciate any advice.
$187.50 labor
