- Los Angeles, CA
- 05 FX35 RWD
Nice times Stu
Removed rear seats and my huge spare tire. And this time I barely had any fuel in the tank.
thats crazy good time stu ! whats the adjusted time, Doc?
I cant believe you can run that fast! awesome
Yes, if you would like, I can take a picture of everything together.So those were the only things removed?
No correction necessary Alan as Dallas Raceway is only 500ft ASL, so time stands without correction.
Usually around 3k, but honestly I usually just punch it from a standstill rather than deal with finding the best RPM's to launch from.What do you guys put the revs too when you torque brake it? VDC off right?
By looking at the times. It seems like the TS ecu flash doesn't do much compared to the stock ecu. It looks so to me but i could be wrong.
That was before Ken had the T/S flash actually. I thought I mentioned that already, but I guess not.Actually all the 45's on the drag times thread has had the TS ecu reflash. We don't have a bone stock 45 to compare. Different elevation's at different tracks and higher grade gas can make a difference.
I'm just going by what he told me when I told him about my latest times a few months ago. Also, it lists Bert on here as having a stock ECU, so there is a non-tuned 45 either way. Or maybe that info is wrong, too?I don't think so Stu. Everything was verified with Ken at the time before it was posted. Unless he gave me wrong information. Plus if there was a mistake, why would he have not corrected me at that time.
That's actually what I did today...watched the tree light then floored it all the way to the 1/4 mile mark.
Does anyone know if this would actually damage your engine? Asking around, got mixed responses from people. Some say that it will not damage your engine/tranny, others say that you will screw up your torque converter...
Because he doesn't come on here. It doesn't matter what the stats are, until someone is trying to compare a tuned vs. a non-tuned time, so that's why I never made a big deal about it. And it's not hearsay if it's fact.
