Was reading the rotorpros website on ebay, they talk about rotor colors. Im wondering do they have the rotors in Jet Black. I see the Black zinc, but it appears to be a little off black. I saw a post where somebody had rotorPros number. Does anybody have it by chance?
I believe it's not the color of the rotors that touch the pads, it's the color of the hub only.. As far as I could remember, somebody here (Psicline?) got them like that and the paint chipped..
Yeah the black paint on the rears started chipping - I just left it. cant really see the hubs anyways with my rims.
Probably best to save yourself some $$$ and not get them painted.
Mine are just fine, but my pads need replacing due to normal wear and tear.
You have to understand, The Rotorpros isnt a high performance part. I think theyre just oem then slotted and drilled. It gives it that sportier look. IMHO they're better than OEM since they got rid of the squeal.
Dunno if rim size would make any difference, but to answer your question im running 20's.
Reason why I ask is because of weight, so then would say that Rotora Rotors are probably better, even though its the same size as the OEM rotor. Im looking for an upgrade, but not BBK. Thanks
The only upgrade without going to the BBK route would be using different pads since Rotorpros or Rotora rotors would come in stock size. There's no difference in stopping power if you go with oem pads with these. I don't know about PosiQuiet but with Hawks it was slightly better after they warmed up..
Probably the best "upgrade" you'd do with those would be the steel lines. IMO, that's the only thing that gives out a good braking feel.
