gchristopher9
- Boston MA
Just got through installing my Kakumei y-pipe I ordered from eBay, and let everyone know what I thought. I don't have any pictures, as I'm sure everyone has seen them on another thread. I just wanted to post my review and advice for anyone planning on attempting this on their own. The pipe itself fit absolutely perfect, like a glove. The one mistake i made was in the front by the cats. The two bolts closest to the middle of the car were able to be turned off with a 14mm socket. The two on the outtermost parts weren't as friendly, so my friend and i cut them off. after they were cut we realized they were welded in from the other side, and we weren't going to be able to just hammer them out. we then had to grind them flush and drill holes in order to run our own bolts though. this was quite the pain in the ass, but once it was done the y-pipe was on in 15 minutes. if your vehicle is newer, or you live in a more undercarriage friendly region of the country, you should be able to just turn the nuts off, and reuse the factory studs. The studs on the rear part of the y-pipe are welded to the stock y, so its easy enough to bolt right up to the midpipe through the factory holes. The bolts supplied by kakumei were a little to big for the factory holes, but we had some spares handy that worked just fine. the sound is a bit louder, and definitely noticeable behind the vehicle. in cabin noise seems to be the same, and it will probably be a few days before i make any performance conclusions. overall i am very happy with this purchase, as I am now ready to bolt up the nismo setup from the midpipe back. wish me luck in finding it!
i also put my grounding kit in today, and stripped the first couple threads out of the front right engine cover mounting hole. gotta try to run a tap through it and see if that works. also, i need to find a longer bolt for the connection at the left front of the plenum. mine wasn't long enough to put 3 ring terminals on. Does anyone know what thread i need? i will also be paying attention to this in the next few days to see if there is any noticeable difference. Thats all i got, more than willing to field questions on the kakumei y-pipe if anyone has any.
oh yea, and the VQ35 sounds insane with nothing after the cats! you know i had to fire it up once the old y was out of there! lol
