aquilles10
I just replaced my rear wiper without removing the arm. It probably took about the same time as removing the whole arm, but that's becuase it was my first time trying it out. It just slides out towards the driver's side as long as you pull down on the wiper blade tip enough to clear the arm's stop.
I replaced the OEM blade with a generic ProLine blade from Pep Boy's (a chain out here in CA). It was the same part number as the 01-04 Toyota Sequoia FYI. I reused the same removable metal guides that came with the original wiper since the did not have the locking mechanism at one end of the replacement blade. It went in easy enough but it's about 1/4" too long. Otherwise it works pretty well. What would be the best way to cut the rubber blade anyway?
