I have a 04 fx35, My initial problem was a bad battery that was not holding charge, the battery I that I had in was a stock one, I then replaced it with a duralast-gold. after replacing the battery when I start my FX it shuts off immediatley, So I thought maybe I need to take a spin for the battery to break in. I drove around for a couple of miles, came back home, shut off the car and started it again. same deal, the car will start and automatically shut off. If I give it a little bit of gas at start up the car will stay on. I ran an OB2 scanner on the computer and came up with a P0102- low input of MAF or VAF- I cleared the code but the car still acts the same. Is there an easy fix for this besides replacing the MAF? has anybody else ever encountered this? its wierd because all I did was change the battery and then this happend..? any suggestions? thanks in advance
