As there are many posts guessing what the measurements are, I went ahead and took out my OEM exhaust and measured the inlet/outlet. I have all the measurements except the y-pipe. I just used a ruler so no real accurate measurements, but enough to give you an idea. Hope this helps someone:
2003 Infiniti FX45 AWD
Y pipe (these are guesses from other posts):
Dual inlet=2.25 inches (please confirm)
Single outlet = 65 mm (please confirm)
Mid pipe:
Single inlet inner diameter = about 65 mm
Single outlet inner diameter = about 63 mm
other random measurements I took:
Distance from inlet flange inner bolt holes = 93 mm
Distance from inlet flange outer bolt holes = 117 mm
Distance from inlet flange side to side = 130 mm
Distance from inlet flange top to bottom = 95 mm
Distance from outer flange inner bolt holes = 86 mm
Distance from outer flange outer bolt holes = 111 mm
Distance from outer flange side to side = 135 mm
Distance from outer flange top to bottom = 95 mm
Rear section:
Dual tips outlet inner diameter = between 90 mm to 100 mm
Mid pipe:
Rear section:
