FX45 OEM Exhaust Measurements Inlet/Outlet
Discussion in 'FX (03-08) - Engine & Drivetrain' started by Chedman13, Sep 9, 2007.
  1. Chedman13
    Chedman13 iS VIP iS VIP
    9,168
    103
    Illinois
    Car:
    As there are many posts guessing what the measurements are, I went ahead and took out my OEM exhaust and measured the inlet/outlet. I have all the measurements except the y-pipe. I just used a ruler so no real accurate measurements, but enough to give you an idea. Hope this helps someone:
    2003 Infiniti FX45 AWD
    Y pipe (these are guesses from other posts):
    Dual inlet=2.25 inches (please confirm)
    Single outlet = 65 mm (please confirm)
    Mid pipe:
    Single inlet inner diameter = about 65 mm
    Single outlet inner diameter = about 63 mm
    other random measurements I took:
    Distance from inlet flange inner bolt holes = 93 mm
    Distance from inlet flange outer bolt holes = 117 mm
    Distance from inlet flange side to side = 130 mm
    Distance from inlet flange top to bottom = 95 mm
    Distance from outer flange inner bolt holes = 86 mm
    Distance from outer flange outer bolt holes = 111 mm
    Distance from outer flange side to side = 135 mm
    Distance from outer flange top to bottom = 95 mm
    Rear section:
    Dual tips outlet inner diameter = between 90 mm to 100 mm
  2. OP
    Chedman13
    9,168
    103
    Illinois
    Car:
    For HKS mid-pipe and rear section, the piping is a simple 65 mm throughout. Tips are 115 mm thought which are larger than OEM tips. I hear HKS Japan has a y pipe but have not been able to locate one in the US or someone who can obtain one. If I do locate one, I'm wondering how expensive it will be as HKS rear section and mid pipe had a hefty premium.
    UTR sold two y pipes, dual 2.25" inlet, 2.5" outlet and dual 2.25" inlet, 3.0" outlet. Both UTR y pipes fit OEM mid pipe (and therefore HKS mid pipe). Pierce fit the 3.0" outlet to his Nismo as well, not sure if the 2.5" will fit the Nismo but it should. OEM confirmed by Bigbody who used a 3.0" outlet UTR y pipe and OEM mid pipe and HKS rear section, all bolted up together perfectly.
  3. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    I see you have been doing to research there Ed!:biggrin:
  4. OP
    Chedman13
    9,168
    103
    Illinois
    Car:
    Yeah, by reading posts I couldn't for the life of me figure out what was true. Trusty ruler helped out=) Just seeing whether my next mod is the intake or y pipe. I did find some Apexi intakes made for the old Q45 that seems to have a 90mm diameter.... we'll see. The M45 has an Injen intake that looks to have the same MAF sensor, I could be wrong. Conrad seems to not like Injen intake due to loss of torque though.
  5. HumbertoCALI
    3,868
    South Gate, CA
    Car:
    2003 FX45 AWD
    Hmm? Can you look into this a bit further and share with us what you find out?
    Curiously Intrested in this...
    Thanks
  6. OP
    Chedman13
    9,168
    103
    Illinois
    Car:
    The M45 looks to have the same MAF sensor connectors to the tubes. Injen and Weapon R cover the FX45's differences (circle and rectangle). Now to hacking up a tube that already is very expensive is not realistic. Since it looks like weapon r has all the capabilities of creating an intake for us, let's just hope someone volunteers (hint hint humberto) to go get measurements at Weapon R. They make cold air boxes, ram air kits you name it.
    Here is where I got the ideas from, see pictures below. Also the Q45, I found some MAF sensor's that were 90mm. They made an Apexi adapter and cone filter to bolt on, but I can't find where I can buy one to test out.
    Here this might help:
    (from LMS Power)
    Injen M45 intake (ebay pictures):
    Weapon R Intake (ebay pictures):
  7. HumbertoCALI
    3,868
    South Gate, CA
    Car:
    2003 FX45 AWD
    Give me a couple of days and I will look into it....
  8. OP
    Chedman13
    9,168
    103
    Illinois
    Car:
    Sweeet! If it isn't too much trouble, ask about intake MAF holes for us old FXers (pre new rectangle MAF holes).
    I did a custom intake with them a while back, they were really nice and responsive. Hope it's the same.
