- South Gate, CA
- 2003 FX45 AWD
I believe that is the Crawford V5 plenum. APS also makes 2 different plenums, one of them being the "Tall Boy."
Kinetix makes the SSV plenum and V+
Looks great....!! Is it say the same as the MREV2 manifold....??
And will it gain extra Hp on a non turbo FX35 with a 1/2" plenum on it...?? I do not read on your aviator that you have it on....??
the after market plenums basically do the same thing as the plenum spacer. According to Motordyne, there is a decrease in performance if you have too much spacing on the plenum (for a NA engine). Basically the aftermarket plenums look nice. The MREV2 is the lower collector and not the same as what Cube described.
Oke so if you'll go for this you have to take your plenum spacer out then...?!
Any price known....?! I like the Kinetix SSV very much any pics mounted on a 35...?! Cause i can't figure out where it would sit in the engine bay.
yes,
http://www.kinetixracing.com/new-ssvextremeflowkinetixmanifold350zg3503-06.aspx
List Price: $999.99
Your Price: $839.99
You Save: $160.00 (16%)
Out of stock
Google is your friend, use "images"
But it can be said to produce the same as the 1/2" plenum spacer then. Allthough it is a lot of money for showuse it looks soooo damn great :top:
The Kinetix SSV will NOT produce similar results as a 1/2" plenum spacer. It is engine bling / eye candy only if you're installing on a NA VQ
The Cosworth is similar, but does have upper end gains on a NA VQ that are hardly noticeable. It starts getting more noticeable as you bump the rev limit and start pushing past 7k I believe...
