2003 - 2008 FX Lighting Specs (Bulbs)
hey i looked around and couldnt relaly find a definate....what would you guys gets to switch out the stock Xenon's to make them a little whiter but still produce a similar visability. I have HID fogs installed and i wanted to match up my headlights to them; to make them all white instead of the stock xenons being alittle yellower. any recomendations?
what temperature are your Hid fogs? All you would do is buy the same temperature bulbs for the headlights.
I would guess 5k or 6k would be your best bet. I have 6k and there is a hint of bluish hue, still very nice though, and not cheesy looking.
I've got a question, I want to replace all my interior lights, my backup lights, license plate, and signal lights.
1. Question is how many interior lights are there?
2. Do I need a resistor to replace my front turn signals to LED's.
Thanks.
I believe its with the positive wire from what I have heard. Not 100% on this as no one has done this that I know of but people have asked previously.
zo if i go and buy a 6000K D2S bulb and replace my stock xenons with it there will be no problems, right?
so these will be okay?
https://www.matrixracing.com/p-4526...er-white-hid-12v-35w-twin-xenon-capsules.aspx
https://www.matrixracing.com/p-4431-piaa-d2s-6000k-hid-super-cobalt-bulbs.aspx
im trying to match them to my HID 6000K fogs
WOW that's expensive...If you want the best QUALITY 6000k D2S bulbs....get Phillips Ultinon 6000k (a true 5800K OEM Bulb) Absolutely THE BEST. You can find them on ebay for around $200.
Any other branded D2S bulb is basically the same. They're all just rebased bulbs. Except PIAA which are just overpriced.
