Skunk 2 spacer install question
alphalink
Los Angeles
Hi All,
I just finished installing the Skunk 2 Spacer but i had a question the kit came with this plastic tube shaped like a "L" it said that it was for the Coolant but when i looked at the area with the coolant line there was three tubes. So i just left it the way it was. Does it make a difference in performance if i had installed that part?
So far the spacer has been great i feel more HP after 4K and paired witht the Z-Tube and K&N drop in my car sounds great. :biggrin:
Nope did not have any L shaped tube when I had mine, I am thinking that it might be a coolant throttle body bypass mod....? Any pics?
I'll try to take some pic later tonight. I think it is for the coolant by pass mod but i don't know which tube is for the coolant. There are three tube that are connected to the throttle body.
i was talking directly to skunk 2 company, they said , they build this kit for 350z and g35 engines, and space compatible with those engine bay. did you find any other problem installing that kit? how much you pay for? you really feel the benefits?
Regards,
Hi All,
I got the spacer from someone over at my350z.com forum for around $150 including shipping. The spacer was brand new and included the nissan oem gasket. with the install i just left off the coolant bypass thing. But i didn't use any silicone for the seal and so far my car been running fine till now.
