Hey Ed, from the picture, did you just install the amp on the side or any other mods from the picture? For example, the bose oem sub/amp, i see looks the same?
SoundStream sound processor is in the side, bolted in.
Alpine amp is also bolted in, right next to it.
Bose amp is on other side, but removed. No need for it.
Stock Sub is used and now has more power going to it via Alpine amp. It hits pretty well for being so small. I saw no need to upgrade at this point or even go with Kicker aftermarket to fit in the bose enclosure.
Depending on my future desires, I can wire coming out from the amp so I can quickly connect an aftermarket sub with box. Connecting it will bypass the bose amp.
Remove the aftermarket sub and box and connection, the bose sub will work.
That way, best of both worlds when I don't need the space.
But... Bose will do for now. They pack a punch when given more juice. Tuned as Tim said to not distort, they work fine.
---------- Post added at 04:47 PM ---------- Previous post was at 04:44 PM ----------
Oh, no cooling fan at the moment. There seems to be air movement, evident from the cooling fins and direction of cooling fins on the OEM bose subs (just a guess).
Cut away the plastic on top for a little more air movement.
Is your sound system done?
