- los angeles
^^+1
def one of my faves
def one of my faves
^^+1
def one of my faves
jeff, how small are your tires? mine are about an inch shorter than stock & yeah, def takes more drop to swallow that extra 1/2" gap, but the good thing is that with a shorter tire you can get even more out of the strut mod... 3/4" is about max with stock size tire but I was able to go 1.25" because of the extra 1/2" the tire allows..
I run a 275/40/20
They are 1.7" smaller than stock according to the tire calculator.
I did the math a while back & from memory I think it increases the front spring rate by a little less than 12% or so... not a huge difference in ride although it is slightly stiffer & of course about 1/2" lower...
one thing I did notice though after the front spring cut is that the front was then a little stiffer than the rear & you can kind of feel the difference... it wasn't until I increased the rear spring stiffness that the whole suspension felt completely uniform again... with just the front cut & the rear untouched the fx bounces slightly off on big dips & the front & rear are not 100% in tune with each other, average person won't feel or detect this much, but that's the only real drawback
The H & Rs are great... i recently installed with KYB shocks and struts and the ride is much better than stock>>>
I cut 1 coil front 1 coil rear!
The ride is not too bad.lol![]()
Can you define better than stock? I think the stock suspension is a bit mushy and gives too much. Would prefer a much sportier ride.
I don't think the H&R or Eibachs will be low enough for me, but I don't want any issues with my suspension because I like the way it looks.
I just installed H&R's with 1/2 coil cut in the front and using the lower spring mount in the rear on the upper. Overall, the car does ride better than stock I think. It is definitely firmer, and on big hits, you can definitely feel the reduced travel. But whereas before on small chatter, the car felt unsettled and bounced around a bit, it feels more controlled now.
H&R provider sportier ride. Coil is a progressive spring rate, the more you compress the harder it is to compress. Therefore on smooth roads your ride will feel like OEM, some say even smoother, but once you get on it, take hard turns, hit bumps, you can feel that it is stiffer than OEM. KYB are the exact same as OEM strut/shocks, so no difference there.
Go any lower than H&R and Eibach drop, you will need a front camber kit and rear camber/toe kit, as your alignment will be out of specs. My H&R's are just within the OEM range. You also have to roll/shave your rear fenders or else your tire will be cut up by the sheet metal.
To go very sporty, you easiest options vs going custom is:
1) http://www.sparktecmotorsports.com/br-v-03.html
2) http://www.autocarparts.com/part/2023/425/ (Murano will fit, just need some slight modification in the rear)
Since there are no other strut/shock options vs OEM, just replacing the springs won't get you "much" sportier. Full coilover is your best bet, but if you don't want the issues listed above, stick with a spring + oem strut/shocks.
Do you have pics yet? Or measurements from the center of the wheel to the lip of the wheel well? Did you get it aligned yet?
---------- Post added at 01:11 PM ---------- Previous post was at 01:03 PM ----------
yeah so my infiniti needs to be lowered...but im not sure what brand to get...any ideas on what looks best (as in how much should i lower it) and which springs i should get?
