sirtrojan
- Poland, Warsaw
- 2006 FX35 AWD
Im not sure if somebody mentioned that oven must be 60 cm wide!
What brand and type of black paint did you guys use that would withstand the heat and freezing temps? Any prep work to paint like sand surface?
I broke off tabs in both headlights (plastic cover in turn signal, you'll see what I'm talking about)
What exactly are you doing to the lights? And will you have pics of the lights?I have a set that I'm working on right now. Should be done by next week if you want them.....
I really want to try this too ! just too scared i'll mess up my headlights !
I did it for the first time last weekend with Handy Andy himself and let me tell you, it was much easier than I expected. I am confident enough to do it on my own now, but still nice to have an extra, knowledgeable hand near by. We baked them at 300 degrees instead and left in the oven for about eight minutes. Wear gloves, they get very hot! It was really easy to pry open with a little muscle. Just pry a little at a time around the headlight at the seams, here and there and it just starts to open up. Lift up on the tabs prior to baking and after before prying, should reduce the chance of them breaking too. The adhesive can get a little messy, like chewing gum, for the most part it stayed in and was clean from prying it open.
I think the oven/baking part is what scares everyone off. Actually, the hardest part is removing the headlights from the car. I'm probably going to change the projectors to clear ones since they are opened up anyways.
