What went wrong with your FX today?
Here is a brief history of my FX45. Not every oil change is listed. Some maintenance items I didn't list. I'm sure I missed some of brakes and tires. At 180K, it still looks and drives great. It has had a pretty rough life - I expect a lot out of it.
7,302 Oil Change
15,648 Tail lamp recall
15,648 Headlight recall
16,726 Oil change
16,726 Alignment
16,726 Replace brake rotors
16,738 Install trailer hitch
17,998 4 Tires
18,844 Oil change
18,844 Alignment
18,844 Reweld B pillar support
29,506 Replace brake rotors & Pads
29,506 Oil Change
29,506 Drivers window motor
41423 Oil change, Air filter
48,145 Dash bubbling - Replaced
48,145 oil change
60,589 Oil Change
62877 Tires, Parada
62877 Brake flush, ATF change
65000 Spark Plugs (LFR5AIX-11) Belts
65000 Oil Change
70000 PCV Valve & Oil Change
70000 Front brake rotors
75,000 Oil Change
80,000 Oil Change
85,000 Oil Change
90,000 Brake rotors, Evap valve
92234 Oil change
94602 Mount 4 tires
97721 Oil Change
104,000 ATF Flush, Radiator hoses, Thermostat, cap
104,000 Oil Change
104,000 Front wheel bearings, pins and nuts
104,000 ABS Sensor (damaged by Wheel bearing removal)
110,000 Oil Change
116340 Tires, Parada
116,400 Oil Change
120000 EBC Blue pads and rotors
123500 Oil Change
123507 Spark plugs and belts.
123000 Rear diff Bushing (Whiteline)
126,000 Starter
130,076 Oil Change
130076 Tires, DWS06
132000 Struts and Shocks (KYB)
132000 OEM Front suspension parts - not struts
136697 Valve cover gaskets & oil change
136697 Power Steering hose
138076 Front drive shaft
139000 Radiator Fan & Clutch (due to fan cracking)
140894 Oil Change
142000 Pads and Rotors
144000 Drivers door lock module
154000 Mass Airflow Sensor (preventative)
147053 Oil Change
152271 Oil Change
160325 Oil Change
161044 Brake pads and Rotors (Parts only)
163000 Tensioner & idler pulley
163000 Belts, Cam postition sensor
163449 Tires - Conti DW06
163500 Brakes - Labor only
165625 Oil Change
168653 Oil change
168653 Brake pads and Rotors (Cryo)
176378 Water Pump, Radiator (Preventative), Coolant, ATF
176378 Diff and transfer oils
176,400 Oil Change
Here is what went wrong with my fx35 today service engine soon came on after i stepped on gas a little harder today then came the smell of rotten eggs in the cabin
Well went to a friends garage service and they used their new toy scanner and the problem was throttle body error tree codes got the throttle body's clean up and two new air filters and voila done
I was having that issue too and had to replace the sensors and then also replace both ducts. The Infiniti mechanic explained to me that for some reason the Infiniti ducts tend to get small cracks at the very end and that was also making the error codes pop up. Once I did all that have not have the issue that had been coming back and forth for over a year.
Yesterday my ac blower stop blowing air. Fuses and relay checked good. I swapped in a new blowrr and no juice. Im thinking the controller is bad. Before i tske it to tge dealer anybody has any other suggestion?
So last night when I was driving home I noticed that my drivers side HID is out. Today I decided to take it out and look at the bulb and noticed that there is basically no coolant in the reservoir. I have no clue what the hell is the issue with this Fx. By I just got a new radiator installed along with the hoses and thermostat and it’s still leaking somehow but nobody knows from where. I might just trade in this FX and get an all black qx70. The only thing is that I will lose the aero kit.
99% sure they didn't get all the air out of the system. 99% sure your FX is perfectly fine.
No detectable leaks, no coolant on the ground after having been driven and parked? Then the leak is in the mechanics head. :rofl:
It was fine for the last few weeks and I happened to look today and noticed the reservoir empty, I actually checked it a few days after I had the radiator and hoses replaced and it was fine then. It’s just weird by I don’t see any leak or smell any burning antifreeze.
The system gets hot enough for a long enough period of time AND/OR some more air that was trapped was then released another way (high rpm for another example) and the system pulled more coolant from the tank. No leaks, no milkshake in place of engine oil, this is it. Put distilled water in the reservoir and keep an eye on it until it remains full.
Man overboard! :eek:
Lost a cap from the driver side roof rail. Not sure what happened, but one minute it was there, and an hour drive later, it was gone.
A/C compressor internals melted and cold air stopped flowing at 24k miles on my 2016. WTF. Fixed under warranty but that's a dumb failure at such a low mileage.
Need help. My radio and climate controls are not working. Picked up my FX50 at Discount Tire and my center dash/display was not on at all with no response to any button presses. DT had to use my spare tire so I decided to checked if amp cable was disconnected. To my surprise, the Batt and Gnd pins on the male connector to amp were completely out from the connector. I shut off the car, disconnected the amp connector, then inserted the pins per manual. The knob lights are back on but no response to any button presses. Display is still off. I had to take off for business trip so I cant troubleshoot until the end of week. I wanted to get some inputs from the forum before I start troubleshooting (check fuses, Voltage levels, etc). Any insight would be appreciated. Thanks in advance.
Disconnect your battery negative terminal for a few minutes, or a few hours, reconnect, see what happens.
Driver front lower control arm bushing had come to the end of it's life. Guess what! It's fused to the aluminium lower control arm so you need to replace the entire table. Cost me a pretty penny.
This has been the first thing to go wrong with my FX; and considering the state of our roads, I'm impressed the others are still fine.
Hi,
I’ve had 3 error codes come up on my car after the EML light came on. They are P1585 Transmission Control Unit Inactive- Throttle Control Unit Malfunction, C1929 Active Steering (HICAS) Inactive - Air Suspension Front Compressor Relay Circuit Failure, and B2428 Rear Hatch - A/C Post Heater Sensor #2. Circuit Failure. Before I get it to a Dealer, I assume they are all linked, any ideas what rage cause may be? My Cruise control also won’t engage now….
If the car was running properly and all of a sudden a bunch of error codes show up, it is often related to a low voltage problem. It could be a battery that has deteriorated, or perhaps bad grounds.
Hi, thanks for the response.
Car was in the dealers today. Oil degradation has cause the EML light, and the cruise control won’t set if any EML is lit. Should get it back tomorrow, although bit disappointed that it also requires the rear strut brace replaced, and rear exhaust due to corrosion. Scottish winters have really taken their toll on the car….
