Denis McGuire
- 2009 FX50 AWD
- Name
- Denis
I recently installed an auto fold module for the folding mirrors. It was a pretty easy installation and did not involve any cutting of wires. The unit comes with a harness that connects between the factory connector and the mirror switch. There are three wires that must be connected, constant 12V, lock signal, and unlock signal. I pulled the 12V from the fuse for the power outlet on the kick panel fuse box. I used the violet (lock), and green (unlock) wires from M119 at the BCM.
You will need a low profile fuse tap, a fuse (I used a 15a), and a few connectors.
What was in the box.
Remove the brown connector from the mirror switch.
Connect the supplied harness between the connector and the switch.
Run two wires from the bcm (violet and green) to the supplied harness and connect.
Connect the power wire and insert the fuse tap. That is basically it.
