Hi Sean, any plans to black out any of the chrome on the sides or back to match the grill? I’m debating that currently.I highly recommend it. The 2017 grill completely transforms the front end of the vehicle.
Are those good for the 2nd gen akebono brakes?
Looks great, is the automatic transmission fluid recommended to be replaced on these cars?Just got the wheels back from powder coat. Also had new tires and tpms sensors installed. When I bought the car back in December, the wheels were in pretty bad shape so I painted them black to see if I would like them but I found that everything seemed to disappear in the wheel well. I decided to have them coated in silver to better show off the 21" size, also had the center caps and wheel nuts powder coated the same colour. While the wheels were getting coated, I clayed, polished (with a 7" rotary polisher), applied two coats of carnauba wax, detailed the interior, painted everything on the suspension that looked like it needed it, and did a drain and fill of the transmission fluid.
View attachment 603293 View attachment 603294 View attachment 603295 View attachment 603296
Have you noticed any improvement in driving since?There are arguments both ways on whether the fluid should be changed. There are a number of threads discussing changing the fluid on this site. My car has 187000 km (115000 miles) so I decided to do a drain and fill. Will do another in about 500 km.
Looks great! And you seem so much happier after the disappointment of painting the wheels black (when will they invent an "undo" button for everything?). I agree that the OEM wheels in black look a bit like a black hole, so I decided to go with a different wheel, 10-spoke, smaller 20" x 9", but the style is better for the black powder coat IMO. I get many compliments on them, and I'm extremely happy (like you). What do you think?Just got the wheels back from powder coat. Also had new tires and tpms sensors installed. When I bought the car back in December, the wheels were in pretty bad shape so I painted them black to see if I would like them but I found that everything seemed to disappear in the wheel well. I decided to have them coated in silver to better show off the 21" size, also had the center caps and wheel nuts powder coated the same colour. While the wheels were getting coated, I clayed, polished (with a 7" rotary polisher), applied two coats of carnauba wax, detailed the interior, painted everything on the suspension that looked like it needed it, and did a drain and fill of the transmission fluid.
Wheels are Ace Alloy Convex, powdercoated gloss black (originally gunmetal).Wow, your 09 looks amazing. The 20" wheels look great on your car. What aftermarket wheels are they? Also, your paint looks new, has anything special been done to it?
There is already an existing power and ground in the Bose wiring harness, but I didn't want to overload it with the new sub and built in amp. I am sure it pulls more current than the the stock setup did.I am curious as to why you had to run a wire from the battery? Is there not switched and unswitched power already on the old harness, or did you need a larger guage?
