What did you buy for your FX / QX70 today?
Installed Q60 shift knob. Definite improvement over original! Still have to match stitching with sharpie. Other than that I’m satisfied with this reasonably low cost improvement.
What did you do to modify knob to the leather sleeve?
Thanks, that's where I bought my 5.0 three weeks ago, lol! Did you swap your camera from the old grill and does it need to be calibrated?
Haha yeah I saw the car you bought listed on their site and was telling my wife that it was a great deal and it won't last long, I was trying to get her to buy it but she's not into anything too sporty .
Yeah I swapped the camera from the old grille, worked like a charm, the whole process is very easy if you know your way around a screw driver :)
for my 1stgen
sunday : smoke outer tail lights ONLY $80!! (inner ones are on order)
tuesday : stoptech steel braided lines, akebono crossdrilled/slotted front rotors (For BBK conversion)
Suspension is on point, rides way better than stock! Will take better pics when it gets nicer out. Also added a Megan racing strut bar up front...
Hey Alex, did your specs after install resemble factory specs with regard to camber/toe? Hopefully it will not prematurely wear your tires. Love the coils! That will have to be my next upgrade.
Hey, I literally just got them installed yesterday so I would not see any wear in my tires just yet. However, it did change my camber just by looking at it. Prior to the suspension and drop, my tires poked out a bit. Now they are flush... I plan on ordering the Megan rear control arms this week and installing them before getting a wheel alignment.
Oh ok looks great bro!!!!
Well done! I’m close to pulling trigger on the 17 grill.
What brand/part# did you use for the fog light? They match well to the your headlights.
I'm using Alla lighTing extreme H11 led
Alla-H11-80W-White-Fog
For HIDs I'm using Osram D2S Cool Blue Boost 7000K Hyper Blue Bulbs 66240CBB-HCB
So I’m not sure whether to post it here or not but I wanted to update everyone... I recently installed BC Racing coilovers on my car... originally I had the damping set at 15 all around and felt they were tight and comfy but wanted a bit more stiffness... so today I decided to set them at 12F/10R from hard to soft... and let me say that the ride is even better. The fronts were left at 4mm from origin preload and set the rears at 8mm preload. I also left the upper rubber hats on in the rear according BC. The car is awd... I had a hard time finding damper settings; hence, me making this post. Have an appt tomorrow for an alignment after riding for a week. Hope this post helps...
