UPDATE FIXED: Two things. I swapped out that fixed the issue, the door lock actuator assembly and the wiring harness for the entire door. One fixed the issue, either actuator or the harness.
I bought a donor left driver door with everything attached and installed it on my car.
Now once i lock the car with the remote control, the window rolls down and stays down.
I changed the window regulator today and did a hard service reset found on the regulator and still same issue..
Can the door lock actuator cause this ?
The new donor door needs to be programmed?
Lastly, do you think i need to switch the old doors wiring harness with the new door?
