It’d be nice if there was something “off the shelf,” from a Titan or some such.Nope. They are smaller but I’m trying to figure out a way to make the FX axles work with them...
Installed 21” gloss black wheels wrapped in 295/40/21 Continental Control Contact tires (Thanks to this forum for all of the tire information, helped immensely in picking out the final tire size).
I’ll be selling the stock 20” wheels with 7/32” tread tires are Goodyear Fortera should last 70k miles, they have about 15-20k miles. If anyone has any suggestions on what these wheels are worth with tires please chime in.
View attachment 589177 View attachment 589178 View attachment 589179 View attachment 589181 View attachment 589182
Installed the Cusco strut bar!
Cleaned out the intake manifold and throttle body while I was at it. What a difference!
Which Cusco bar was it? Was it the
Cusco 288 540 A Type OS
found it on amazon for $169.99
Thank you just ordered!!!!Cusco Strut Brace Infiniti G37 https://www.amazon.com/dp/B008KU014M?ref=yo_pop_ma_swf
The picture that is used in the url above does not reflect the actual look. It is flat not round.
Let us know how you like it!Thank you just ordered!!!!
You can accomplish that ratio, albeit one legged, with a differential from the correct years AWD version...10% quicker?Nope. They are smaller but I’m trying to figure out a way to make the FX axles work with them...
I’m keeping an eye out, prefer LSD, but those stubs were the deal breaker for me. I’m not racing for money. There’s nothing “wrong “ with the one it came with other than that, and they are supposed to be indestructible.
Other than the pads are you going to need to purchase anything else to replace the existing calipers?View attachment 591201
Great deal on BBK calipers! Less than $200!!! Rotors and pads ordered. Still contemplating what color to paint, but leaning towards red. Suggestions are welcome.
Good luck, let us know how it goes!Through my research here and across the internet I’ve found the only items required for this upgrade for 2nd gen is the larger rotors. The dust shields will need to be trimmed or removed as well.
Thanks!!! Will do!Good luck, let us know how it goes!
Thanks! I ordered rotors for a 2013 FX50. I thought the the banjo bolts only needed to be shortened for 1st gen models. I have a 2014 QX70. Correct me if I’m wrong.Be sure to order FX50 specific rotors because the FX chassis has bigger parking brake than G/Z chassis. Also, you will need to shorten your factory banjo bolts if using oem lines or if you choose to use stainless steel lines you will need the FX50/G37s/370Sport specific banjo bolts, you can’t use the ones included in a FX35 kit.
Just picked up banjo bolts! Waiting on G2 paint kit and rotors to arrive tomorrow! Hope to have this finished this weekend! Wish me luck!I stand corrected. I read it wrong when researching. I can purchase the banjo bolts locally from Z1 Motorsports.
