E3A300
- 2013 FX30D S Premium
Hi all.
Installed the Fortin Evo-NIST1 remote starter with T-harness last week on my 2013 FX utilising the guide on here and the OEM remote fob but I'm having problems.
I can remote start with 3 x preses of the lock button on the fob but I can't switch it off with 3 x presses of the same button, which I belive should be the case. Neither can I unlock the car with either the fob or the keyless button until the remote start has completed its timed duration. Pressing unlock with it running just sounds the horn with each press.
After the initial install I left the car locked for several hours only to find the car alarm sounding at midnight, so I rushed outside and the car alarm had by this point stopped, and the engine had now remoteley started on its own! It was at that point that I realised I could neither cancel the remote starter or gain access whilst it was running.
I have A1 to A11 checked
B3 Unlock Double Pulses checked
C1 OEM Remote Monitoring & D1 Standalone Remote Starter checked
D2 Auto Unlock & Disarm Checked
D6 Push-To-Start Checked
As mentioned above, the car remote starts from the fob but I can neither cancel this from the fob nor access the interior via the fob or keyless entry button whilst it's running. I have programmed the module several times using the flashlink, spent hours reading old posts on here and technical info on the Fortin site but I'm none the wiser.
Any ideas?
Any ideas?
