teemoney
- 2007 Infiniti fx35
I drive an 07 fx35. Last year I was getting a vacuum leak, drove lo Ike that for a year and then was getting misfiring. Found the vacuum leak came from the gasket that goes under the plenum. Had upgraded to motordyne spacers so changed that gasket. Removed all the motord6ne parts (except the copper throttle body gadket) and changed a coil packeaners. Car dr8ves great but will go in limp mode at any time. Took it to a dealership twice and they said they can't find anything wrong or any codes. I do have the two cat codes p0430/420 only. So what I notice is while I'm driving, my wipers will move much slower and 5 minutes later the vdv/slip/abs lights come on and I'm in limp mode. If I let it sit turned off for 45 minutes it'll drive perfect again. Checked brake fluid at dealership and it was low so they topped it up. Anyone have any ideas at what to check next? Just frustrating as I can't drive far cause of the limp mode
