Wheel fitment
jfx35
West Covina, CA
2006 FX35 RWD
Hey guys,
I'm new at buying wheels for an SUV and was wondering if anyone can help with the following questions.
I found a nice set of wheels that I really like in the following specs (this will be square setup on a RWD FX35)
20x9 (offset available are +36 or +25) which one is better?
Tire size they recommended is 265/50/20 (is this the norm for this spec?)
I do plan on lowering it later on using H&R springs will I have fitment issues?
Thanks for the help.
Jay
Go 25. I'm lowered on 10.5 x 25. Nothing a little roll can't fix (if you even need it on 9s) I trimmed my rear and small tab bend on fronts. What year are you?
Personally, I go with square because I can rotate my tires. I want my tire to last!
20 x 10.5 +45 is not too much. If you want your tires to flush with the fender, you can still add 20 mm spacer. My wheels are 24 x 10 +45 with 25mm spacer.
Do you have a picture of your setup?
so if I go 20x10.5 +45 square I shouldn't have any problems lowering it in the future? no rubbing issues?
Sorry for all the questions, just want to make sure I buy the right specs for my FX.
I have 21x10.5 +30 square and 295 tires on coilovers with no issues
