akachi
If you heat it at the right temperature, it becomes malleable. I was also surprised it was able to handle all the curves.Dang, that's surprising, I figured the 3m would be a little too thick for all of those curves and angles.![]()
My dealership also recommended only a drain and fill... TILL they got a unit that did the flush... Then of course, that's what they recommended... My first change was just a drain and fill at the dealership and now that I have a mechanic I can trust, my second transmission fluid change was also just a drain and fill (and this guy finally fixed my issue with changing from R to D in cold weather after the fluid change -- first fluid change at the dealership to address the same issue didn't work)...Every mechanic I have ever talked to about it, mentioned that doing a pressurized flush can damage seals and gaskets, and possibly dislodge(but not get rid of), potentially harmful debris/build up.
 They charged me a little over $200Sweet. Love the way she seats. Love her more with all green alignment specs.
How much did the shop charge for the rear control arm installation?
Is that like a headlight restore? Did you use a kit? My baby BADLY needs a headlight restore... I've seen some friends butcher theirs on EASY headlights, but with the curves of ours, I wonder if it would be even harder to do nicely...Gave it a nice deep cleaning bath, then used Mothers back to black, and polished the headlights. After 4 hours I am pretty happy with the results.
Looks GOOD!!!Upgraded front bumper/grille conversion. The grille is wrapped gloss black. The look of the car flows so much better now!
BTW, the new camera plugs right in and works just fine.
that white and black looks sick!Upgraded front bumper/grille conversion. The grille is wrapped gloss black. The look of the car flows so much better now!
Please do! Hopefully the Walmarts in Canada will have the kits as well! For $7, I would risk butchering my headlights :PYes, it is a two step headlight restore. Bought it at Walmart for like $7 bucks. I can share a pic of the bottle this afternoon once I get home.
Really easy to use and results are instant. You can use a toothbrush and tooth paste, that cleans and removes slight scratches as well.
