Athlon
- Austin, TX
- 09 FX35
How much for front and rears along with H&R springs shipped to 78754?
PM'd!How much for front and rears along with H&R springs shipped to 78754?
Thanks for your order!Got mine ordered and on the way! Thanks Zebra!
Hi guys, ordered my 24x9.5" rims today for my 2012, and I will be lowering with H&R springs. The tires get very expensive at this size; do you think these would definitely make the tires last longer?
Great ideaWhen you guys get them installed and aligned, please post up your specs in this thread:
Megan Adjustable Control Arms
Can I get a price on fronts, rears, and coilovers please
Sent from my SM-G920P
Is it a pretty easy DIY? Also do i have to go to a performance shop to get these done if i didnt want to do it myself? or can like a Good year do it?
My camber is pretty messed up on the passenger front due to some potholes and a accident. Would it be bad if i got front and backs and put them all on coilovers? I guess I'm concerned since the front passenger is so out of line and i try to drop it would there be a problem anywhere?
Also can i get a PM on possibly a full camber set and some BCs
Pm sentPlease PM me for a quote, thanks
Yes, you can do it yourself or any performance shop can do it. Please PM me for a quote. Thanks
Know of any performance shops in socal that would install the springs and camber kits?Please PM me for a quote, thanks
PM'dKnow of any performance shops in socal that would install the springs and camber kits?
PM'dCan you pm price of rear camber kits shipped to 98230?
Ed, I need these ASAP. And I would like to have them sent straight to the dealership for installation.Car alignment is absolutely crucial when modifying your car. Alignment can effect every aspect of your driving experience, from straight line stability, under-steer, over steer, acceleration, braking and tire wear. Although stock components allow slight alignments from the stock suspension settings, they often are not able to properly align the car after the suspension has been modified. From the factory, most cars are set to have under-steer and for optimum tire wear at stock height; under-steer is often undesired from a performance standpoint and almost all performance driven applications are lowered.
Megan Racing Inc. has developed reinforced and adjustable control arms to accommodate the needs of the aggressive and performance oriented tuner. Being constructed of a Lightweight Steel-Alloy which is able to withstand the stresses of extreme competition, these arms are powder-coated with a 3-Stage process to ensure durability and protection against the elements.
Alignment is crucial to the handling of your vehicle. Remembering that the only thing that touches the ground is your "Contact Patch" of your tires you have to make sure that your tires and wheels are doing exactly what you want. With this you must make sure you have the proper camber, caster and toe as well as make sure they are all working together and not against each other.
SPECIFICATIONS & FEATURES:
- Constructed of Steel Alloy for Lightweight yet Durable performance.
- Hard Rubber bushings for a more direct feel and driving experience.
- Easy to access turnbuckle-style adjustment.
- Can be adjusted without removing from the vehicle.
- Eliminates Premature Tire Wear while improving handling and stability
-Sold in pairs
Will fit 2009+ Infiniti FX35/FX37/FX50/QX70
Please email me for pricing! Thanks for Looking!
Hey, checking on that for you!Ed, I need these ASAP. And I would like to have them sent straight to the dealership for installation.
Found these, is this a good price?
Shopping Cart
Part number MRS-IF-0210 was successfully added to your cart
Megan Racing Camber Kit (MRS-IF-1190)
Camber Kit
Position : Front Upper
$ 235.50
Megan Racing Camber Kit (MRS-IF-0210)
Camber Kit
Position : Rear Upper
$ 427.50
Thank youHey, checking on that for you!
