Yes sorry, I meant to clear that up. It is a direct fit. @la_fx35 I should have taken step by step pictures but decided to wait on it since I still have the other side to do. That has yet to come in unbroken... Ill make one if someone doesn't beat me to it.
First I took the seal off under the trunk lid (the part with the brushed aluminum), Next was the spare tire cover, and seat hinge covers? after that you can remove both sides of the spare tire wall. Lastly you just need to separate the side panels from the body, once the trunks floor is up it'll give you enough space to get in and swap the cable.. It helps a lot to have a panel puller(red thing in the photo) and 10mm and 12mm socket as there are quite a few bolts/screws to remove.
I do like that Limited badge. Looked on the Infiniti site... sadly not available? They list it but no price.
Found a badge. Not sure why they made it a different part number, maybe theres a difference but you can buy the limited badge from the QX80
K0890-1A60B
So are these tail lights easy to install or a pain in th ass?
Where did you order all this from?
