smellmyfart
As title says, i just realized it the footwell lights are always on while driving? Is it supposed be like this? Is there a way of turning them off?
THanks.
THanks.
ah... it makes now. i used to ugly oem yellow bulbs. I replaced them with t10 led. It is bright enough for me to notice its on while driving. I got used to my s4. The footwell lights are on only when doors are open not during driving. Thanks for your help.mine are lit up as well but very dim. It only brightens up when the doors are opened.
You can use the dash brightness to control their brightness . I'm glad they are always on because it adds a bit of ambient lighting and look good if you put in a LED rather than the stock bulb.
Thanks for the picture JayCSmoov! That doesn't seem too bright - I may have to grab some more LEDs.They are blue.View attachment 334379
Do you have a picture of the footwell lights while the door is shut? I'm considering swapping out the OEM bulbs for LED, but in worried it may be too bright.
Dumb question here, how do I get a little lenses off to replace the bulbs for the foot well? And what are the bulb numbers?
Thanks, I should've looked harder.They just pop right off, I used my fingernail but you can use a flat head screw driver if you like..Very simple
I picked up a pair at Walmart for $8.95, number T194 I just put them in the foot well but I may have to get some more .Thanks, I should've looked harder.
I can't even tell they are on when I'm driving, on,y notice it when I turn the car off and open the door.
