I'm stuck with a 10 mm stripped bolt on the heat shield. 10 mm close or box wrench spins around it. Can't get 9 mm or 3/8" wrench on it. There is not wide enough space to put a socket and ratchet on it. Any ideas?
View attachment 13392 View attachment 13393
A couple toothpicks inside the 10mm socket to take up the space to prevent slipping... attacking it from the bottom of the car won't fit with ratchet+socket?
@gold & pork, the gap is too narrow to fit a socket & ratchet. I've tried vice grip and one of this bolt extractor socket. All no go. Also the tab that bolt screw into is weaken that when I apply pressure against the bolt using a ratcheting wrench, it bents inward. So I have to chisel around the it from the bottom to remove the heat shield off the exhaust manifold. Since the heat shield is mounted with 4 bolts, I should be ok with using just three. Once I got the manifold off the car, I should be able to take the shield off and try to patch up the hole that I chiseled.
Andy, I'm interested in how this goes.
I'm about to tackle the same problem a little differently. I was going to cut the OEM cats off the manifold and weld on flanges to bolt up new cats. Considering access up in there, I don't know what challenges lay ahead.
My car still up on jack stand. I was able to take out 4 nuts with ease, 2 came out with the stud, 1 nut sort of stripped, and 1 still unable to remove. This last one is a real PITA. a standard short socket is to shallow. A deep socket is way too long when adds on a universal joint. So I ordered a set of "Semi-deep" socket in hoping that it will help.
Pork, I highly doubt there enough clearance for welding. I post up some pictures so you can see. Just taking good pictures of it a pain in itself.
Ok pork. Here are some pictures to show you how I think it is impossible to weld on a flange onto the manifold pipe.
Here is how the exhaust manifold looks like.
Here is the top view of space you have to work with. I toss a coke can in there so you can have some comparison. It impossible to do any cutting or welding from the top. Can't even see the pipe from top view.
Here are looking at the manifold from underneath the car.
Same view. The red outline is the mainfold exhaust pipe. The green circle is the O2 sensor port location (its on the top side of the pipe). The blue outline is the steering wheel shaft. Again, the coke can to give you a visual of how much space available to work with.
I highly doubt is can be done your way. Best is to replace the entire manifold like I'm doing now.
- Replaced rear lock hatch actuator
- Oil Change
- Cleaned and re-oiled the Stillen air intake.
Using my Safe Note 7
Ok pork. Here are some pictures to show you how I think it is impossible to weld on a flange onto the manifold pipe.....
Thanks Andy for the great pictures and explanation!
I've got some thinking (and measuring) to do if I can use the HFC's. Or just stick with OEM replacement.
